Exhaust covers? Which Ones fit?
08nytromtx16
Happy Valley Goose Bay NL
Hey can someone with some knowledge of exhaust covers tell me what covers will fit this exhaust?? I know normal vector ones wont but will apex/apex mountain ones fit and what about rx1 covers will they fit it as well? By the covers I mean the side plates, endcaps, and that rear plastic part that covers up the rest. So does anyone know which ones will fit and also if they will just bolt on to my 06 nytro thanks.
I think the old RX-1 will fit with a little modification. IMO they were the best looking ones.
From your picture, I can see that there is a little black thing (shround) that mounts to the tunnel with a black phillips head bolt. On my attak, that is where the exhaust shround mounts.
Long story short, I cant see why you cant just get apex covers, tips and rear plastic and be good to go.
Also, what exhaust is that? RX1 and apex have different length exhaust by about 2 inches longer for rx1.
Well from what Ive been told it is a vector mountain exhaust and im not sure if the apex plastics will work because of different shaped taillights therefore different rear plastic peice.
It definately looks like a mountain exhaust judging by how the tips flare out to the side and it is a vector exhaust because the exit tubes do not angle out the same way as an apex/rx1 exhaust does.
Nothing of the apex will work, unless you modify the exhaust to exit at a different location. This is only to my knowledge, maybe someone else will chime in...
If you take a look at a Mountain Vector you will see that Yamaha did NOT make any new plastic for this sled. Yamaha used Apex side covers, Apex Mountain tip covers & RX1 tail light covers. They only made a new muffler. If you look at previous brochures you will see that it was only the Mountain Vector SE that recieved this exhaust setup to allow for the tunnel rack.
