towing
I had replaced my 3 exhaust pipe seals in the middle of the last season at around 7500 miles (they were disappeared ).
It work great at first but i begin to hear the same rattle i had (between 5-6000rpm) and motor noise that tell me they are shot again (2500miles since.. )
I had not replace the collars at that time because they were B.O. but i had grind down the stopper on them to ensure they were tight... i suspect that it was not enought...
So i order a set of seals and collar and will do the job again as soon as i will receive them.
I wonder if somebody had try to put high temp rtv gasket seal when installing the new pieces ??? If it can support the high temperature, it will absorb the vibrations and give a longer life to the fix ???? what do you think ???
Permatex Ultra copper is supposed to hold 700 degre C , i think i will try it...
Bye
Alain
Bye
Alain
..from Towing:
700 C is somewhere close to 1300 F.
The Gen 120 throw out 1390 F about 6" away from your donut, that is, where i located my thermocouples. Now, do what you want.
Have you squeezed the gasket tight with the 3 into 1 piece before installing the collars ?
le druide
Vous pratiquez votre anglais les gars!!
Salut
Salut
Roger
- Feb 10, 2007
- Osgoode Ontario Canada
- 2012 RS Venture GT (power steering doesn't work when real cold)
2006 Indy 500
Parlez Anglais s.v.p.le druide said:Vous pratiquez votre anglais les gars!!
Salut
Metallicat
I am noticing more of an engine rattle in the 6-7k range now. I wonder if mine are going south, too, after 2600 miles. Maybe it is just the Supertip weights?
snoway
I have a snare drum rattle upon acceleration throughout the rpm range, thought it is just the muffled sound of the engine growl..lots of talk about the exhaust donuts.http://www.ty4stroke.com/viewtopic.php?t=55416
Just hit 3300 miles.on the 08. i will take a peak when its (snow)melted.
