1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
- None, looking now!
Who out there has the expert without the crappy dtr? I took mine off and need to know the measurements of the stock ( non-dtr ) limiter straps. Need to know the over all length, and where all the holes are. I have some material here to make new ones, I just don't know what size or where to put holes at.
Any help would be great!
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
Or if someone has a copy of the install instructions for the dtr I can figure it out. I do recall them saying how much to cut off.
Ratpack
- Oct 11, 2006
- Frewsburg NY
- 2003 RX1
I used the same straps when I took my DTR off. I will look monday and see what holes I'm using.
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
That would be cool. I still used mine as well, but just sitting there, the straps are tight. Thinking there should be allot of play in them. I think I am on the one of the end hole of the 3. ( Making it longer. ) There is one more hole further up from the 3, maybe I should use that. I am running a 144 with no studs, so I want allot of transfer to get the traction needed.....especially since it's over 200 hp.
Ratpack
- Oct 11, 2006
- Frewsburg NY
- 2003 RX1
The bottom of the strap is wrapped around the bar and right back to it's self. The top wraps around the bar and goes in the fourth hole. That is counting up from the bottom. There are 4 holes in the middle of the strap.
This was the set up that we got from Bovin. I have the weight transfer bar set to no weight on the skis. That and 240 hp = lots of fun. Anything else just ask. I will see if I have the set up sheet from them. If I do I will email it to you.
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
Sweet, thanks bro.
Ratpack
- Oct 11, 2006
- Frewsburg NY
- 2003 RX1
1 CrazySledder. PM me your email and I will send you the set up sheet. It was to big to PM you.
