tonykof
Anyone know where I can get rail extensions for an 2003 M-10? I want to go from 121" to either 136" or 144" If they were setup to go to 8" big wheels that would even be better.
Thanks Tony
Thanks Tony
LazyBastard
www.tracksusa.com -- $99.
You don't want to go 144 with rail extensions, they would be 11.5" long and would significantly compromise the strength of the skid.
tonykof
Do you know if anyone makes them setup for 8" wheels? Those offset axles are a pain to adjust..
LazyBastard
Why would you want 8" wheels? All they do is reduce your clearance to the top of the tunnel.
tonykof
I guess I've never had any problem with them hitting on my extend Pro-X & it helped alot with rolling resistence on the track. But maybe its different on a Yamaha.. thanks for the heads up.
Tony
Tony
monker
I have a offset axle on my 136" m10. performance engineering sells them
www.hiperf.com part number 560-456(b). It is harder to adjust the track tension, but nothing that is terribly difficult.
