snowriderjoe
- Feb 23, 2006
- Champlin, Mn
- 2014 Yamaha Viper L-TX
Has anyone had fault code 22 come on? Mine did today. Stayed on for about 20 miles.looks like it is for an air intake temperature sensor.
LSXM3
Have u had the airbox off recently?
LSXM3
snowriderjoe
- Feb 23, 2006
- Champlin, Mn
No.
Just replaced the exhaust donuts.also just changed the oil. Today when the warning light came on I found that the oil tank level sensor had came off and thought maybe that was it. But the light and code stayed on for about 20 miles
yamahinn03
- Dec 28, 2004
- oshkosh, wi
- 12 Nytro XTX (mine)
06 Apex GT (wifes)
07 Phazer (#2 sons)
02 Viper (#1 Sons)
Intake Air Temp Sensor, PTO side of the air box, check and see if it is unplugged... Had the same issue at first start up...
Andyfreeze
- Apr 27, 2011
- Colrain, MA
- 2012 nytro xtx
http://www.ty4stroke.com/viewtopic.php?t=83992
save this to your favorites..good info to be able to find quickly when ya need it.
snowriderjoe
- Feb 23, 2006
- Champlin, Mn
Thanks for the input.
So today I checked the sensor on the airbox. The connection seemed tight and everything looked OK.
When I started the sled the warning light and code 22 came up again.
So I ran the diagnostic check.
According to the chart, diagnostic code 05 is for the intake air temperature sensor. When I ran the diagnostic it said the air temp was -30 deg C. (obviously not right).
As a check I also checked code 06 which is the coolant temp thinking both should be close to the same. The coolant temp. was 26 deg. F which was probably about right. So I'm thinking the air temp sensor is bad.
It would also stay off sometimes when I started the sled and come on other times.
What do others think? Any other thoughts or ideas?
yam177
- Aug 14, 2008
- Shoreview MN
- www.jbeurotech.com
snowriderjoe said:Thanks for the input.
Wire connection is brittle there, I would gently pull on the wires. You may find a broken one
snowriderjoe
- Feb 23, 2006
- Champlin, Mn
I will have to check that. The wires seemed fine. I ordered a new sensor, it was only $20, so hopefully that is what it is.
Not sure if there is a way to test the one I took out??
bnsf205
Had that on my Phazer I didn't see the wire was cut by the black tubing over the wire until I cut it back.
snowriderjoe
- Feb 23, 2006
- Champlin, Mn
Installed the new temp sensor today.that was the problem.
