Got a Fault code 43 yesterday, and thanks to this site i quickly figured out the reason for this.
heated up the fuel relay and it started right up. It didnt start today either, so i must have it raplaced. I dont get any faul code now, but the oil light in dash is lit and i dont hear the fuel pump starting. Seems this is a common problem on Nytros....?
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
Its a known issue.
Heat it up or knock on it to get it running while you wait for the new relay.
birkebeiner
- Jul 27, 2009
- Norway
- Norway
- 2015 Yamaha SR Viper X-TX
Got my first code 43 as well this Easter. The sled has almost 4.000 km on it and was sitting outside overnight in -25 C when she decided not to start. I bit hot water on it an problem solved. However, did happen two days in row.
Is the only cure to change it?
Ironically it happened first day after I installed the Roest / Mountaintech instrument panel vent kit...
Twistgrip
This code came up for me the 2nd day I owned the machine on a trip it didn't start and code 43 came up. It was the ecm in the front right behind the tool bag. He took it out and dried it with a heat gun, plugged it in started right up and I haven't had a problem since. He did have to go through a bunch of steps on the dash to reset it though.
