jdp1under
- Oct 19, 2009
- CT, NO SNOWVILLE
- 2010 RS VECTOR GT LTX STOCK FOR NOW!
Hello guys I did a expert x conversion this year and I have put a few thousand miles on it and love it. I had set it up according to the manual for my riding style and weight and have not touched anything but the trasfer knob above the softness bar. I think its soft for me but I wanted to give it a run before making adjustments.
2003 rx1 151 expert x 1.25 ice ripper
set up code for skid is CD
riding agressive 5'8 230lbs
I was wondeing if i mess with the shocks or the shock angle?
Thanks jdp
Thanks jdp
grader
the shocks have cam style adjusters at the bottom for preload adjustment. the shock angle raises or lowers ride height. the overload springs have 2 slots to choose from to control bottoming.
jdp1under
- Oct 19, 2009
- CT, NO SNOWVILLE
Thanks where should the overload spring be set?
grader
it depends on your weight and riding style. if you are a big guy or always jump the sled then set to max, lower hole on arm. i actually drilled an additional hole higher on the arm so the spring wouldent engage untill later, made the ride softer with less rebound.
jdp1under
- Oct 19, 2009
- CT, NO SNOWVILLE
Ok thanks ill be checking it out later this week im going to spend some time dialing in the skid.
