First Repair on Rage
MedoraRage
Houghton Mi
It was quite a run, 6730 miles with no problems. Had to end sometime. THis was also an opprotunity to see if the extended warranty is worth anything. The left drive axle bearing failed causing the axle to shift in position which then led the speedometer gear to chew up the speedometer sensor. All three had to be replaced. It was all covered by warranty!! :Rockon:
