![](/styles/vip.gif)
kviper
If you think your stock Apex is impressive, This clutch kit will put a grin on your face that may never go away. Backshift is awsome and than instantly pull's much harder at least to 95 when i had to get out of it. Crusing RPM did not change much at all so gas milage should not be an issue. Good job Jeff !!! Very nice gain's and a riot to ride.
kviper
welterracer
How much did you pay for it? and how much faster is is supposed to be compared to stock?
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Was the sled ridden with stock clutching first for comparison?
kviper
$380, 1/2 second in 1/4, That is what the gain was on the tar and Jeff say's the snow will be about the same due to the sled making more power in the cooler weather, That is what they have seen in the past. Less drage on the asphault but less HP in the higher temp's as well. All i can say is it is a gain that the seat of the pant's will definatly feel. kviper
kviper
Mighty i put about 10 MI on than put the kit in and went back out and put another 4 on with the kit. kviper
