Rx1M5
Ok finally got out on the new turbo in the mountains today and all in all it ran pretty darn good. I won't go into rants about the power as I'm sure you've all heard it before but holy crap does this thing rip and I don't even have it turned up yet. Here's what happened today.
1st off I haven't got a fuel pressure gauge yet so I don't have a clue what that is set at but I will get one and set it to about 5 lbs at idle. Correct?
Does the fuel pressure at idle affect WOT A/F ratios? I was seeing these numbers today:
- 4-7000 rpm 10-11 cruising on the trail
- 7-9000 rpm 14-15 and the odd higher value while climbing
- WOT climbing mid 13's dropped into the 12's one time the odd time it stayed up towards 14
I am jetted at 127.5 17.5 pilot needles stock (2.5?) riding at 6500 feet temps around freezing today 9 lbs boost. Using Parkers knock box I got I think it was 10 knock events over 3 pulls. Will hitting the rev limiter simulate a knock event?
I'm thinking I need to fatten the main jet but how many sizes I'm not sure. Will 130's bring my A/F's into the 11's at WOT or should I go larger and what is a good target for WOT A/F?
For that 7-9000 range should I change the needles?
I know these are a lot of disjointed questions.
Thanks in advance for any help.
Rx1M5
Rx1M5
