rla1
- Jan 4, 2015
- saskatchewan
- 2017 sidewinder btx le,2021 mountain max le,2011 apex xtx,2012 arctic cat xf m8
Looking for info from the more experienced.I have a 07 apex with a stage 2 mpi s/c that I'm taking to the mountains for the 1st time.Will be riding around 9000 ft.have been told I do not have to run race gas at that elevation just premium 91+,also that the sled will not run unless I cut a hole in the hood and extend the intake tube out.
Jbat
- Jan 8, 2015
- Yamaha Apex-McXpress Turbo
how much boost are you running and do you have a head shim? And we extended all our intakes out the hood even on the stage 1 because they couldn't get enough air under the hood.
rla1
- Jan 4, 2015
- saskatchewan
Running 14psi boost,no head shim,10:1 low comp pistons,falicon rods,falicon crank,bosch piggy back fuel pump,gems fuel controller,a/fr wide band 02how much boost are you running and do you have a head shim? And we extended all our intakes out the hood even on the stage 1 because they couldn't get enough air under the hood.
Jbat
- Jan 8, 2015
If your riding at 9000 feet and you have low compression pistons you can get away with running straight 91 octane. It wouldn't hurt to mix a couple gallons of race gas in a tankful to be on the safe side but it isn't necessary
rla1
- Jan 4, 2015
- saskatchewan
Would you suggest just using gems high altitude settings and tweek mode 6(altitude comp) once I am up there and leave clutch alone.with s/c I would think I would be able to keep rpm's up?
Ratpack
- Oct 11, 2006
- Frewsburg NY
- 2003 RX1
I have had mine in the mountains without cutting the hole. Have thought about but I did not want a hole in the hood. I'm sure it would be nice with better air.
- 14K
