First Yamaha 4 stroke
ssjet
Hello, I Bought a custom sled last Saturday (auction). Got some questions. Not only am I new to Yamaha, but new to posting pics. Hope it works- The paper work says RX1 Warrior. A warrior is a RX1 with a 136 track? It looks short to me.
I thought It would have about the same performance as a stock 600 two stroke. But this one hits harder than I want. I follow every two track i find and speed isn't always needed. My clutch is engaging around 4500 and has a white spring. The secondary spring is black with a grey dot and after market helex. Custom intake and exhaust is two loud. This thing really fast!
I found on e-bay factory spings, cam arms and helex, Is this the right step at making the power more smooth?
Mixture seems lean at mid range, cracking a little at 40 mph, but accelerates with out any hesitation any suggestions?
Can any one tell me about the drain on the air filters?
Thank You :rocks:
It's not a warrior. That's a 121" with the mono shock suspension, which makes it an 05 I believe unless someone installed it into an older sled. It has an Apex seat installed (higher). And obviously clear plastics, intake filter kit, LEDs under the hood......
