verticalnytro08
Hi guys and gals, my sister in law has a 06 nytro with fox floats. I noticed that the shocks traveled about 4 in b4 the skis came off the ground, so I am wondering if anyone knows what pressure to set the shocks at for a rider that is a buck fourty. also for all you nytro owners, did you get an air pump and a guage when u bought the sled. Any help is greatly appreciated, let it snow.
rtkota360
yes the previous owner gave me the pump with the sled.You can get one from ebay or dennis kirk.As for adjustment i havent ridden it yet so im not sure.Im gonna just keep the pump on the sled and adjust as I .Good luck
verticalnytro08 said:Hi guys and gals, my sister in law has a 06 nytro with fox floats. I noticed that the shocks traveled about 4 in b4 the skis came off the ground, so I am wondering if anyone knows what pressure to set the shocks at for a rider that is a buck fourty. also for all you nytro owners, did you get an air pump and a guage when u bought the sled. Any help is greatly appreciated, let it snow.
I believe, regardless of rider weight, you want the front a-arms parallel to the ground. I run 45-50 psi in mine and it works great. Also you must make air pressure adjustments with front end off the ground- NO weight on ski's. Air pump w/gauge came w/ sled from the factory. Hope this helps.
verticalnytro08
thanks ithink that is what i needed to know. ill try it and see what happens
7 skulls
nytrodude is right on. I run mine at 55psi (175lbs of hard charging rider) for better/flatter handling and a more compliant ride/easier steering. I only need to add air for jumping.
Adjust the pressure with the weight off the ski and the pump should have come with the sled.
