sleddingfarmer
09nytro said:Heres what i got , Powder Pro ski's , 6" shapers , No Sway Bar .
, 95 psi in shocks ( I will look in my book to see where the comp. and reb. are set ) front strap up one hole and rear up one hole with polaris wieght transfer blocks set on 2 ( Again i will look in my book for shock setting )
Good luck and have fun with it
Those Polaris transfer blocks, they bolt on with only one bolt correct?
I had a similar style, just one bolt vs the factory 2 hole design. My rails started to bend and crack near the transfer block. Luckily I saw it before I snapped them off. Put stock back on and it hasn't gotten any worse.
Just a heads up, the 1 bolt design might cause too much stress on the rail. Either that or I drive like a idiot.
09nytro
mine started to bend to but made a plate to reinforce it becuase i ride like an idiot tosleddingfarmer said:09nytro said:Heres what i got , Powder Pro ski's , 6" shapers , No Sway Bar .
95lbs in the front shocks? Did I read that right. Might be better to replace the floats with a piece on steel square tube! Does the front end even compress? I ran 47lbs in my attack and I guess Im shocked that so much pressure can ride good!
revster
- Aug 18, 2004
- La Salle MB
- 2009 Yamaha Nytro RTX SE
bottlerocket said:09nytro said:Heres what i got , Powder Pro ski's , 6" shapers , No Sway Bar .
95lbs in the front shocks? Did I read that right. Might be better to replace the floats with a piece on steel square tube! Does the front end even compress? I ran 47lbs in my attack and I guess Im shocked that so much pressure can ride good!![]()
Looks like he has a SE so those are Float Xs. Not sure if it makes a difference but seems so. I run around 110 - 120 psi in mine. (No sway bar)
I believe i read 150 psi max but i never heard of the pressures being this high on sleds....
