flooding?
tylerdirty
Yorkton, Sask, canada
heres my question i have a mpi supercharged rx1 i bought it never built it so dont know a whole lot about it. The problem im having is its flooding at idol for some reason when i unhook the electric fuel pump its good till it burns the fuel up. When i drive it, it seems fine. But at idol it floods so bad it kills itself fills oil full of gas. Is the a fuel regulator? or what could cause this? i cleaned the carbs and same thing?
Thanx
Needle and seats in the carbs are leaking .Remove the intercooler ,turn on fuel pump without the motor going and look inside each one of the carbs and see if there is any fuel leaking pass the seats.
You might have to clean them if they are not worn .You have to check first if they are leaking.
