vice108
I wanted to see what others have been using for air pressure, how much they weigh, and how it's been working so far.
I have mine set at 90 psi but have not ridden yet. I'm about 235 naked. Based on early season reports I might drop the pressure down some.
fourndog
I set mine at 100psi but i do not have many miles on mine yet. I set it to 100 because i figured it would be a good starting point since they say to set them between 50-150 psi.
I started at 100 and have moved up & down depending on conditions. Last Sunday trails were very rough dropped to 60#'s and ate the bumps right up. I weigh 180. 125 was very stiff my range will stay between 60-90.
Throttle Jockey
- Dec 12, 2005
- Fort atkinson,wi
- yamaha
Put on 80 miles last night, in rough and some smooth trails, had the shocks at 70, and it never let me down, I weigh about 235 with all the gear on
BA APEX
I put on 75 miles last week. I weigh ~300. had set on 75, seemed good but I'm going to try other settings also.
TT670
I weigh 235 and I lowered it to 60 to get the nose down in an effort to improve cornering. It does bite better into the corner but has a touch more roll in the chassis,It has yet to bottom out. I cant imagine anybody needing more than 80 pounds.
MADDOG24
I am running mine at 85 PSI. Seems like a good balance. Im 240 pounds. Sled has 300 + miles
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
- None, looking now!
I wiegh in at 200 lbs, alittle more with gear on of course. At 80PSI I would flip the sled going into corners. (Had to let of the gas or I would've gone over for sure. ) At 80psi I think the sled sits to high for trails. I was out last night at set them at 65psi and made worlds differance. Now the sled sticks to the trail pretty good. My transfer is set at MED. and it will still lift the front enough to put the lights into the trees, but atleast the sled sticks so I can corner well.
Vince
Vince
vice108
I think I'll start at 75 now.
Fast_Eddy
- Vanderhoof (area) Canada B.C
- www.sledwest.net
I have mine at 65 at the moment. Im only 170lbs.
I have not rode it to much cause the lack of snow but it seems alright. once we get some snow and i can start into the jumps ill be pumping it up and tuning it alot im sure
vice108
Ran at 70 today for the first time. It seemed tippy - I may try 65 next.
i have mine set at 65,and cant feel anything up front,turned the transfer down a whisker under standard
vice108
RED800 said:i have mine set at 65,and cant feel anything up front,turned the transfer down a whisker under standard
How much do you weigh?
I may turn the transfer down a bit also. It lifts the skis like crazy.
