Yama-Crazy
- Jan 10, 2005
- S/E Michigan
- 2014 Yamaha Viper rtx
I hear the gas float shocks are stiffer and lighter and wondering if I add these if I can avoid going with stiffer sway bar? Anyone have any idea? I just want better handling less body roll. :? Or will the sway bar still help even with gas shocks...looking for opions. thanks
jimmie d
One costs about $1,000 the other about $75. I guess I would try the bar first.
Jim
Jim
Yama-Crazy
- Jan 10, 2005
- S/E Michigan
those damn shocks are that much to add?? :shock:greenmachine said:One costs about $1,000 the other about $75. I guess I would try the bar first.
Jim
jimmie d
A little more than Ohlins clickers.
Jim
Jim
Yama-Crazy
- Jan 10, 2005
- S/E Michigan
Ok guys thanks I'm gonna go with the 13mm sway bar!
Tork
Fox floats ar $885 at Goodwins. They could REQUIRE the 13mm bar because they are so progressive in their action.
impalapower
How easy or hard is it to change the swaybar?
SRXSRULE
899.00 is list from yamaha. A good dealer should be able to take 15% off that price if you buy much from them. Anyone want to know the price of that electric adjust Ohlins?......... 995.00 for one shock! Ouch!! ===SRXSRULE===
impalapower
Shocks aren't cheap. I think spending money elsewhere would be better. Just my opinion.
I tried the 13mm swaybar with the Fox shocks and it was a bit too much. I went back to the stock bar. Never tried a 13mm bar with the stock shocks.
impalapower
lawndoctor said:I tried the 13mm swaybar with the Fox shocks and it was a bit too much. I went back to the stock bar. Never tried a 13mm bar with the stock shocks.
I heard stock shocks and the 13 was the ticket. Ride hard and corner flat, ride easy and its tippier than stock.
Yama-Crazy
- Jan 10, 2005
- S/E Michigan
I ride pretty hard so will be getting 13mm sway bar!
Tork
Rage2005Yamaha said:I ride pretty hard so will be getting 13mm sway bar!![]()
First I've heard about it being used on the RS sleds as it has the geometry that the 4 cylinders get in 06 which is more roll resistant by design.
Yama-Crazy
- Jan 10, 2005
- S/E Michigan
Good point...well I still have some body roll ..but maybe I should go to a 12 then?? but 1st I'm gonna try putting alittle more down pressure on my skis see if that helps 1st?? thanks Tork didn't know if it would help or not and if anyone has tried it on an RSTork said:Rage2005Yamaha said:I ride pretty hard so will be getting 13mm sway bar!![]()
