JD
- Apr 14, 2003
- Manitoba, Canada
- 2016 Venture TF-LE
I need to have my shocks redone.....I have a FAST M-10 (121")....I bought my skid new with the FOX Zero Pro shocks the rear has the remote adjustable clicker...The guy that I am trusting to do the shocks says he needs to know the IFP depth of these shocks....Can any of you tell me this information.....and anything else he may need to know.....I have tried to contact FOX with no success.....Is there a manual for these shocks....HELP....weekend is approaching....Thanks
JD
JD
AaronBND
Here is a chart that shows the IFP depths:
http://www.carverperformance.com/ifpchart.htm
Looks like the front shock is 1.150" or 4.160" (depending on shock part number) and the rear is 2.400"
Hope it helps you out!
Aaron
Aaron
You will be able to see the small wear area that represents the stroke of the internal piston quite clearly on any used shock. The internal piston moves only a very small amount and will allow you to be very close to the original setting. Just measure and record this for future reference. This ensures that there is no additional error during susequent rebuilds. I place the piston at the deepest portion of the wear mark and use this measurement. This will give excellent results.
Birdman
You can also order a owners manual for that susp. from fast . I know that it has all the rebuild specs as well as set up advise
