Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
I was of on some real rough trails , with some spine tingling bottom outs .
Switched the setting from Med to firm and felt a noticeable difference that allowed me to ride more comfortably faster .
What are those of you with this system doing for your 2 custom settings ?
idontknowjack
- Mar 22, 2020
- SW Ontario
- '20 SRX
Driver 1: Soft front/Firm rear
Driver 2: Medium front/Firm rear
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
when you change from all firm to your custom settings , what difference do you get ?Driver 1: Soft front/Firm rear
In otherwords what does softening up the front achieve ?
idontknowjack
- Mar 22, 2020
- SW Ontario
- '20 SRX
If the trails are smooth, I find it steers better. More in control.
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
soo i just changed my centre shock to the 24 clicker shock from a 2016 zr6000 XC, and added the HyGEAR TWISTED dual springs to it and the the front iQS shocks, originally the factory had 3" sag on front from and on high speed trails with big whoops would bottom easy even setting on firm would be to stiff and jarring, i just installed the twisted set and set to 2" sagg and the middle shock at .250" pre load afer install. OMG what a diff, yes the sled sits a little higher in front but now i have all on soft setting and sled just soaks up the studders and whoops. i just gave HYGEAR my 220LB weight and the sled and they sent a matched set up.... so far soo good.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
where are you in Horseshoe Valley ?soo i just changed my centre shock to the 24 clicker shock from a 2016 zr6000 XC, and added the HyGEAR TWISTED dual springs to it and the the front iQS shocks, originally the factory had 3" sag on front from and on high speed trails with big whoops would bottom easy even setting on firm would be to stiff and jarring, i just installed the twisted set and set to 2" sagg and the middle shock at .250" pre load afer install. OMG what a diff, yes the sled sits a little higher in front but now i have all on soft setting and sled just soaks up the studders and whoops. i just gave HYGEAR my 220LB weight and the sled and they sent a matched set up.... so far soo good.
Just delivered a AC bumper to someone in Cathedral Pines .
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
in sugar bush just over next hill
