06 Venture track tension
I found the factory specs. too tight which caused my hyfax to wear out rapidly, had to change the Venture at 2000 mi. and my Vector at 1000 mi.. The factory specs. call for 1-3/16" to a maximum of 1-3/8" drop with 22-1/2 lbs. pull or weight at the center of the track, on 06 ventures and Vectors. I measure distance from the top edge of the track to the bottom edge of the hyfax, with the track pulled down.
On my Venture I leave 1-1/2" to 1-9/16" opening with 22 lbs. If I go anymore, the track sags a lot and is dragging on the two guide bars located on the forward upper end of the suspension, so I don't go any more. This has reduced my hyfax wear quite a bit. Also note, the sliders on the Venture seem to wear down a lot at first and then the rate of wear seems to slow down quite a bit.
On the Vector, useing the same method, I'm running 1-3/4" drop and that seems to work well. A friend is running 2" on his Vector with no problems.
