robertyoke
- Jan 23, 2008
has anyone run a turbo nytro without the front heat exchanger? using just the tunnel cooler and radiator for cooling.
i went with the 3 inch camo 174 and was thinking of moving the stock front cooler forward but there is only about 3/4 inch from the oil filter to the exchanger with the mcx oil supply spacer behind the oil filter. so if i move the exchanger 1/2 for the track the oil filter is going to be a lifetime filter because its not coming off.
i know some have deleted the radiator and dont have a problem. and others have deleted the tunnel cooler and dont have a problem....but what about the front cooler?
bagadonitz
Was there not a filter relocation kit of some sort for vectors or something? That could help.
