I have asked it before but want to get the front end down on my rx for handling purposes in the trail and was wondering what all needs to be changed to achieve this? There is some speculation that it may just be the spindles and shocks on some other posts here and I would like to know before I get serious about this. Also, is the vector and the apex front end identical because if they are that would probably help support the arguement of just changing spindles and shocks.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
-Spindles
-Spindle housings
-Upper & Lower A-arms
Also the Vector upper A-arm is alot smaller tubing diameter than the Apex. The Apex a-arms are built stronger.
-Spindle housings
