nytro15
- Mar 18, 2009
My front right shock is squeaking with every move up and down. Is this a potential problem and is there a fix?
upei93
- Apr 27, 2008
- Dalhousie, NB
- 2015 Viper X-TX LE MPI turbo
2009 Nytro XTX
My front end squeeks and it's my bushings and ball joints...lift the front end up and check for play.
Maine-Rider
Mine did the same thing. Ball joints had some play in them. Yamaha warrantied them.
upei93
- Apr 27, 2008
- Dalhousie, NB
2009 Nytro XTX
Maine-Rider said:Mine did the same thing. Ball joints had some play in them. Yamaha warrantied them.
Thats where mine is going...dealer told me they will replace everything once, then I'm going with ulmer's bushing kit and Crewchief47's ball joint fix next year.
Maine-Rider
Ill probably get a bushing kit as well. The Yamaha ones are junk.
nytro15
- Mar 18, 2009
Thanks for the info i will look at it this weekend..
Straight_up_XTX
I had a simmilar problem last year... I was having squeeking noises comming from the upper a-arms. I just took the upper arm off and greased the bushings by hand (since there are no grease fittings). Problem solved for now anyway.
