Fuel additives?
Lemonbomber
Ok this has probably been discussed before. However, from some of the local mechanics and now the news we are being warned about the 10 percent ethanol in our gas. It is being suggested that we use an additive to fight corrosion and condensation in our engine/carbs. Is this really an issue if you are fuel injected like the Phazer?What about my wifes' Vmax? HAve you guys found an additive that you can recommend. I did put Fitch Fuel pellets in both sleds but that only helps with gas deterioation is my understanding. :4STroke:
I too would like to know about the additive to combate ethanol, as I have heard of several engines down due to ethanol.
Saw a product called k100 in action this weekend.
saw a demo where they filled a cup with some water and added the k100 and basically burnt everything in the cup.
I have been reading bits and pieces about it for a while now but finally saw it in use. looks to me like it works. also claims to stop phase separation.
The stuff is kinda expensive though. i think it was like 8 bucks a bottle to treat 20 gallons
