I keep seeing all these different controllers out there. I currently run the Pure logic box that came with my cpr kit. Where can I go to get instructions for this box. I have gotten told what numbers to run for my sled but I still have a hard time understanding which setting does what? Also I know of features availible that I don't know how to use or read. All and all, I know nothing about these controllers and want to learn more.
My controller is the type that plugs into every injector if that helps anybody.
Thanks in advance
aj
Thanks in advance
aj
ultimate
- May 14, 2005
- ,Quebec
- uniklabels.com
- Yamaha apex
look that!
http://ogdenvalleysports.com/
joker2
try dean at alpine motor sports. 1 250 804 4334.
he can program them and probably answer your questions.
Darren
Darren
Jeff’s controller is custom built and programmed for his turbo application just like the rest of the manufacturers. So he would be the one you need to talk to.
See this thread: http://www.ty4stroke.com/viewtopic.php?t=51518SIMONS CPR said:>>> My box is different from all others <<<
2nd circuit is amount of accelerator fuel added. 5th circuit is sensitivity of when it adds accelerator fuel. 6th circuit is when green circuit (mode 1) switches to red circuit (mode 3) based on load. You will only trigger yellow circuit (mode 2) when load is rapidly increased, it is on for less than 1 second, to add fuel, to eliminate any lean condition in the transition from the cruise (green mode 1 ) circuit to the high load (red mode 3 circuit). By controlling sensitivity and amount of fuel on accelerator circuit, you get the best of both worlds. Throttle response and fuel mileage. My controller is the only one that has this feature.
Thanks hammer, I seen that in my other post when I was trying to get numbers, but after getting the numbers set, I was still looking to learn a little more with the box. I realize now that they are programmed different for different applications.
I will call jeff and find out what I am looking for.
thanks
aj
thanks
aj
- 6K
