insane
I ran 180 miles with no issues. Started popping when going from mid to w/o for a few miles then went from there to popping and the afr was way lean up near 18. I have a 2:1 regulator with a fuel pressure gauge on it and the pressure was dropping from 45 psi to 25 psi back and forth rapidly. When i adjusted the regulator to a higher pressure(70 psi) it smoothed out and the sled ran fine. I thought I had a bad fuel pump(inline walbro 393) so I replaced that with an in line walbro pump gsl 392. Went out for a ride and sled ran fine for about 5-10 miles then it started going lean again and got progressively worse, the fuel pressure seemed like it was holding steady this time though. Also, both times the fuel pumps made a high pitch squealing sound when they started at the turn of the key. I am running the stock fuel regulator with the 2:1 reg in series with the stock injectors. I plan on modifying my stock injectors and using only the stock regulator, hoping the regulators are the problem. I just don't get why it ran great for 180 miles.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Sounds too complex with your fuel system. My upgraded 255 lph pump supplies plenty of fuel for my maxed out stage 1, with the stock regulator. Can u just do that or no?
insane
Complex, as in too many regulators? That's the way I'm leaning. I am running about 13-14 psi so I think I am at the peak of what my injectors in stock form can handle.
insane
Has anyone run both regulators together? What is the ratio on the stock regulator?
heath@mpi
- Aug 20, 2008
How much boost are you running and hwat is your elevation?
thanks
thanks
kinger
- Jan 17, 2005
- Clear Lake, IA
Yes complex as in too much stuff on the fuel line. If I rear right your running two regulators, two fuel pumps correct?
The factory is a fixed regulator holding the psi spec (40-45lbs somewhere in there) your aftermarket one is a rising rate and tied to boost as you know so it ramps up as the boost does.
I'm not a fan of uping the fuel pressure unless you really are forced to its hard on the injectors to open and close with 60+ psi on them and can shorten life.
If it were mine I think a big in tank pump 255 lph, then the stock or the rising rate regulator but not both. Preferably stock would be best.
What boost are you running?
DC5
The factory regulator is a rising rate 1:1.
kinger
- Jan 17, 2005
- Clear Lake, IA
Really I never heard of that thought a regulator was just that regulates a certain fuel pressure.
Cool guess I learn something new every day...
insane
I'm running 13 lbs of boost. I'm pretty sure that with the modified injectors the stock regulator will be sufficient for what I am running as there are guys running alot more boost with the stock regulator. I'm just concerned that there might be something else wrong. I just wanted to know if someone else ran tandem regulators and had the same problem. I am only running one fuel pump as I got rid of the stocker and the stock pick up and installed hurricane's fuel cell plate with a filtered pick-up off that. It is really a nice clean mod for improving your fuel system. Correct me if I'm wrong but I believe these pressure sensitive regulators do regulate fuel pressure based on barometric pressure so that a efi sled doesn't have to change jetting based on altitude (in stock form anyway) the stock regulator is set at a fixed pressure and gives 1 psi of fuel pressure to 1 psi of boost where the aftermarket is adjustable and gives 2 psi of fuel for 1 psi of boost. They actually should work together as long as I set my mapping to the right afr for the combo. I just would like a scientific explanation on why I am going lean after the sled warms up.
heath@mpi
- Aug 20, 2008
There is no reason to install 2 fuel pressure regulators.
The single 1-1 is best. if thats not enough change injectors.
insane
heath@mpi said:There is no reason to install 2 fuel pressure regulators.
I agree, and that is my next step, but why doesn't the two work? I guess one could be choking off the other one, but why does it not do it until miles into the trip? I guess I'll try this next step and if it solves the problem then I'll analyze what changed. Just trying to wrap my brain around this. Thanks for your help guys.
