Fuel pump relay.
Ironically it varies positon! I read on here it was the 3rd one in and mine was actually the 2nd one. I'm not alone other said the same thing. What I have to do is turn the key on and feel for the click then I know I got it.
You can identify it by the wire color indicated on the wiring diagram excerpt below.
I took my shop manual and looked up all the color coding to identify each relay mounted above the left foot well, then proceded to take a black sharpie marker and write above each one on the foot well. The click trick works also. Good call.
-Rich
