Jona$
Master
- Sep 27, 2010
- Northern
- Sweden
- Tapex/sks 800 -16
Noticed today that the pump did go on so checked all and the wire aswell the pump were ok. could also here the realy clicking.
took the relay of and warmed it and tapped at it. Put it back and the pump went on.
What i am thinking about now is that on the blueprint it show 3 off the 4 relays having the same number, how come? i mean there can only be one fuel relay?
and i suppose a relay can click even due to that it doesnt work?
http://www.portyamaha.com/fiche_section ... &fveh=6869
NY_SXR700
- Dec 30, 2003
- Webster, NY
- www.sohonetworksny.com
- 2001 SXR700
2006 Apex-GT
Just so I know about this fix (which I had know about for some time) which one of them relays is the fuel pump relays. There is 4 of them there. Like you said 3 of them are all part #30 on the drawing. With any luck the fuel pump is not #29.
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
there is a tech bull out you need to replace it with this # 8HG-81951-00-00 relay and you also need the holder 8HG-81952-00-00 put the new parts in they are from the 11 apexes this fix is for all apex 06-10
chiefsledhead
Three of the four are interchangeable. The fourth one that is different is the headlight relay. If youu get stuck, change any of the other two with the fuel pump relay and it should fire up.
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
darv said:there is a tech bull out you need to replace it with this # 8HG-81951-00-00 relay and you also need the holder 8HG-81952-00-00 put the new parts in they are from the 11 apexes this fix is for all apex 06-10
any chance you can post that bulletin for us please?
FLYBYU
If you had the fuel pressure gauge you would of saw this alot earlier.
- Mar 1, 2004
Rich Kay
- Mar 29, 2006
- SE MI. Howell
- Yamaha apex rtx
From what I've been told (by auto engineer) relays have an industry standard in there make-up, just go to any auto store and match the terminal layout to and it will replace what you have.I have done this with a ski-doo by pulling one out of my F-250 and fixing the problem.
Rich Kay.
Rich Kay.
darv
- Aug 9, 2005
- 08 Apex 40th LTX
the relays from yamaha are like $9.00 and the new holder $8.00 cheap
