fuel pump relay clicks, but no go
whisky700
Winterpeg
Hello, I have an 06 Attak, the other day I filled my sled up with fuel, turned the key, heard the relay click, but no fuel pump whir sound. After checking all connections and rapping on the relay, still no go. I then shook the sled, lifted the front and back and dropping, then the fuel pump worked. Worked all day fine. The question is, do I have a fuel pump problem, or a relay problem? Thanks in advance.
So after a search on the forums, it looks like the relay could still possibly be bad, even though it clicks. I will replace that asap. It also looks like it could also be the ground wire on the pump. Is this wire accessable if I remove the seat? Any other locations for this possible bad ground wire?
