Ful pump relay on 2015 vector ltx
TrueBlue
Franklin Park, IL
Trying to find out which relay out of 4 of them is the fuel pump relay on a 2015 Vector ltx. They are located above your left foot on the inside of the engine compartment. Also I would like to know if this relay is the updated solid state relay. In prior years they had a problem with the original relays sticking because you shut down the machine too soon after starting it. If possible I would also like the new NO. for the solid state relay and in what position is the fuel pump relay in.
Thank's in advance.
Rich
That machine should have the updated relay in it already. It is red in color.
Part # for updated relay is 8GN-81950-00
Fuel pump relay is the farthest one to the left if you are sitting on the machine
