vsmpowered
- Feb 16, 2009
- Rochester , NY
- Nytro xtx Viper ltx se
what is the gear difference between rtx se and rtx? and clutch engagement between them?
2008 Nytro RTX
Nothing,Only difference is the SE has a better/more aggressive shock package.
vsmpowered
- Feb 16, 2009
- Rochester , NY
why the clutch engages at higher rpms
2008 Nytro RTX
I don't own a SE so I can't tell you why,But as far as I know they have the same clutching!
Bpatch50
clutching
No, the clutching in the SE is different. I don't remember the details but the primary spring and weights (rivets) are all different. If you do a search I believe Allen (srxspec) posted the details somewhere.
Gearing is the same
2008 Nytro RTX said:I don't own a SE so I can't tell you why,But as far as I know they have the same clutching!
Gearing is the same
towerrigger
The SE also has some different reinforcing on the rails that the RTX didn't come with.
jeffT
dont forget the white handguards too
vsmpowered
- Feb 16, 2009
- Rochester , NY
what about performance wise speed and acceleration
2008 Nytro RTX
I know there is little things,Big one being the suspension. I didn't know about clutching and I still am not sure they changed it.
stopdropanroll
- Oct 8, 2008
- Fall River WI
- www.styleonecustommotoring.com
The tunnel design is not the same, SE shares the same tunnel as the XTX
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Primary spring on an RTX SE is a blue-white-blue
Throttle Jockey
- Dec 12, 2005
- Fort atkinson,wi
- yamaha
SE has a different primary springvsmpowered said:why the clutch engages at higher rpms
Bpatch50
clutch
I'm sure. We have an RTX, a SE, and a XTX in our group. All three came with different clutch setups.
2008 Nytro RTX said:I know there is little things,Big one being the suspension. I didn't know about clutching and I still am not sure they changed it.
vsmpowered
- Feb 16, 2009
- Rochester , NY
thanx for the replies
