DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I believe Hurricane and TD both use the GAP flasher cable. If this is the case could one have both Hurricane and TD tunes on the same cable?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
I wondered same thing, and Im not sure we will ever know. lol
My guess is one would have to try it to find out.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
I don't think so. Pretty sure flasher is registered to vendor and then obviously vendor loads flashers and you grab them off server and down load to flasher.
DMCTurbo
- Nov 12, 2005
You could really compare apples to apples in back to back runs.I wondered same thing, and Im not sure we will ever know. lol
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
that is true.....and it would be cool as I have a few TD buds and a few Hurricane buds , would be nice to flash them all with one cable.You could really compare apples to apples in back to back runs.
Im not sure anyone really knows the specifics yet, unless they have one and have flashed sled already.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Flasher only recognizes one ecu.
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
Not true. They have said already that the flash bundle is vin locked. Not the flasher itself.Flasher only recognizes one ecu.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
OK. So can you put two bundles on one flasher for two different ecu's?
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
I'm not sure what the procedure is bit Ben said you can flash your buddies sleds with your flasher as long as they purchase their own bundle.
Turbo Dynamics
- Jun 16, 2016
- Gatineau
- 2017 Yamaha Sidewinder
2014 ZR9000 turbo
- Gatineau, Quebec, Canada
- turbodynamicscanada
- YOUTUBE
- TurboDynamicscanada
One flasher can do unlimited amount of ECUs. So you can flash your friends etc...
Each sled can receive up to 10 flashes for the same VIN. But the flasher can hold way more than that. The limit is high enough you will never reach it
My tunes are in a different server. Dave cannot see my customer's flashers and I can't see Dave's. We have our own tunes on our own server.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
That being said, Does that mean a flasher can only see the server of whom the flasher is bought from?One flasher can do unlimited amount of ECUs. So you can flash your friends etc...
Or can a person connect to any server with any given flasher?
Turbo Dynamics
- Jun 16, 2016
- Gatineau
2014 ZR9000 turbo
- YOUTUBE
No, it's locked to a specific tuner.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Thanks Ben, that is what we all wondered....I assumed so but good to know!No, it's locked to a specific tuner.
