doober
i lift mine up at the track and put it on a small stool, then slide a long plastic taboggan under the skid, catches about 80%of the water, then squeege the rest out the door.
Cubby
- Dec 14, 2009
- South of Winnipeg, Manitoba CANADA
- 2015 Ski Doo 900 ACE Renegade Adrenaline
2007 Yamaha Phazer GT
doober said:i lift mine up at the track and put it on a small stool, then slide a long plastic taboggan under the skid, catches about 80%of the water, then squeege the rest out the door.
Best idea yet. I had a long red plastic toboggan what would be perfect - threw it out last year when it cracked. I will keep my eye out for one.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Storage Bin Lid
An upside down lid from the large Rubbermaid storage bins would work. Just put 2 underneath the track and it would catch all the drippings.
MS
MS
RoyalBlue
- Jul 20, 2008
- Lead , SD
- upstaging.com
Re: garage mat
Keep it simple like TOMBOB , I use old towels and then a box fan
TOMBOB said:I think you guys are making this to difficult. place sled in garage over drain
use a tarp and cardboard make tent over your sled use a turbo heater
20 min clean use rubber hammer get hard stuff
TOMBOB
09nytro
My heat is set to 55
Put my sled over drain and go in the house.
Why can't you put a drain in ?
doober
09nytro said:My heat is set to 55
They wouldnt let me do one either when i did my garage, think it has something to do with contaminates getting into the soil or something like that.
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
doober said:09nytro said:My heat is set to 55
I'm guessing it is more like the floor drain hooked to the sewer system is a danger. I know of a few places that blew up because of people dumping volitiles down the drain and the fumes entering someone elses building.
I have no floor drain and all I do is knock off the ice and snow if any! Then I just put a large blower fan behind the sled and evaporate the water away as the ice melts. I think people are on the right track with tote lids they would make perfect catch pans.
But any water that is on the floor will evaporate easily with a large fan or blower. Mine is a furnace blower. I also have a dehumidifier that I can use if the humidity gets to high but with the wood heat the dehumidifier is only used in the summer.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
just leave it outside with the ice and snow still on it it just going to get back on it again next time you ride. then again some of us dont havethe big beautiful heated garage. mine is only heated when i fire up the wood stove. and i use the push broom to push out the water when im done working on it. other wise it has all the snow and ice on it from the whole season. but then again i ride right from yard almost every night so when i come home i just throw the cover on her and call it a night. i know what and why you are asking just had to chime in.
doober
Sasquatch said:doober said:09nytro said:My heat is set to 55
wouldnt even let me put a drain into the ground, i assume for the same reason you stated..people that dump oil and such down the drain. I was going to dig a deep hole and put gravel into it and use that, but they said no!
doober said:wouldnt even let me put a drain into the ground, i assume for the same reason you stated..people that dump oil and such down the drain. I was going to dig a deep hole and put gravel into it and use that, but they said no!
Where do you live ??
Cubby
- Dec 14, 2009
An easy option for me- like thor452 - would be to leave the sled outside. I too ride right from my house but I prefer keeping the sled locked safely in the garage when not in use.
Keep it locked up and out of sight around here. I leave my sled on my single trailer in the garage and have a hole drilled in my salt shield with a 5 gal. pail underneath. It also is a good height for working on sled.
doober
Central BC Canadasteiner said:doober said:wouldnt even let me put a drain into the ground, i assume for the same reason you stated..people that dump oil and such down the drain. I was going to dig a deep hole and put gravel into it and use that, but they said no!
Glenn
I leave the sled in the trailer till next weekend ...lower trailer door jump on seat a few times ...start and go
Don't forget every time you heat up the sled you will get some condensation into the gas. Cold to hot
Just my two cents
Just my two cents
Yup easy solution. Just drill a small hole at a min in the floor with a concrete drill hit. You can always patch it with hydraulic cement and no one will be the wiser.
1/2" should be enough to dissipate the water.
I assume the slope is wrong and the water puddles in the corner or something like that.
