09xtxrider
I partially removed the gas tank to install CR10EK spark plugs.
I only disconnected the tubing towards the top of the tank and 1 of the plugs on the gas tank. I re-installed everything. And now my gas light is flashing.
Did i mess something up when i disconnected the plug without disconnecting the battery.
Or did i just forget to plug something back in?
thanks
thanks
Tarzan
- Oct 28, 2009
- Norway
- www.youtube.com
- Norway
You've come to strands of wire to the fuel gauge which is on the right side of the tank09xtxrider said:I partially removed the gas tank to install CR10EK spark plugs.
Did i mess something up when i disconnected the plug without disconnecting the battery.![]()
thanks
Tarzan
- Oct 28, 2009
- Norway
- www.youtube.com
- Norway
Think it is a green plug on the wire.
09xtxrider
Tarzan said:You've come to strands of wire to the fuel gauge which is on the right side of the tank09xtxrider said:I partially removed the gas tank to install CR10EK spark plugs.
thanks
Sorry tarzan, i dont understand what you ment. I have come to strands of wire??
thanks for you help!
raptordan
- Jul 5, 2004
- Barrie ont.
- 2025 SRX
I had the same issue this weekend.There is a green plug on the right side of the gas tank,its for the fuel gauge plug it back in and your good to go.
09xtxrider
Ohh okay.
thank you!
thank you!
Tarzan
- Oct 28, 2009
- Norway
- www.youtube.com
- Norway
raptordan said:I had the same issue this weekend.There is a green plug on the right side of the gas tank,its for the fuel gauge plug it back in and your good to go.
Tarzan
- Oct 28, 2009
- Norway
- www.youtube.com
- Norway
Hehe sorry my bad english ,you have a lose green plug on your right side of the fuel tank just beside the reverse its the plug for the fuel level to the gauge09xtxrider said:Tarzan said:You've come to strands of wire to the fuel gauge which is on the right side of the tank09xtxrider said:I partially removed the gas tank to install CR10EK spark plugs.
thanks
09xtxrider
Yup, just tore the seat and side panels of in 28 deg. weather, and of course that plug was disconnected!
thanks for the help.
LET IT SNOW!!!
LET IT SNOW!!!
