Gearing Combo for Phazer MTN Lite Turbo
Brent_P
Kippens, Newfoundland
I did some searching on TY with mixed results on gearing combination for a boosted Mountain Lite.
Im looking for some advice on what a good setup is for gearing/clutching on this sled. Currently running stock gears with stock clutch (MCX weights added) however i need better top speed. I would like to achieve 90mph, currently the sled seems to govern out at about 75-78mph.
Would like some opinions from people with this same sled boosted.
I put 9 tooth drivers on mine and it seems to work fine. Only downfall is the speedo is out but I think it is around 87 mph. Helps aproach angle on the track slightly and is cheaper than changing gears by a little.
