kragos
- Sep 15, 2023
- Narvik
- Norway
- Apex MTX
Looking for a part number for an 18 tooth top gear (i have reverse if that makes a difference) it is for an 08 Apex MTX, i found one number but not sure if it will work with reverse, the number i found is 8FA-17682-80, i assume i should go to a smaller chain also, what is the suggestion for that? Thanks for any input.
8FA-17682-80-00
Just note that a sprocket that small shortens chain life a lot.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
I have a brand new Yamaha 18 tooth gear on the shelf if you can't find one send me a message.
