Gems controller and AFR numbers explained?
ApexGTman
Newfoundland
Canada
Hers - 2017 Sidewinder XTX LE
His - 2015 SR Viper RT-X LE MPI Turbo with Ulmer Stage II Clutch Kit
2012 Apex SE
2006 Apex GT, Stage 2 Ulmer Clutch Kit, Ulmer Stealth Mod Air Box, 144 1.325" Woody's
2003 - RX1
1998 - SRX
1993 - Exciter SX
1992 - Exciter II
'15 RTX LE with MPI trail turbo. I finally know my afr numbers but I am wondering how the numbers are affected by the gems controller. I know there are 5 different numbers for the GEMs setttings but I have no idea what each number represents.
Last year before I had my gauges installed and was doing some drag racing I noticed that my viper would back fire when I got hard on the throttle. Now that I have my gauges installed I notice the the AFR numbers drop into the 9's if not into the 8's at the 6600 - 7200 RPM range. would this be considered rich and could it cause it to back fire at times?
I also noticed at WOT AFR drops from 11's and 12's to 9's and low 10's.
If I knew what each color represents I may be able to make some minor adjustments now that I actually know my AFR numbers.
Any info or ideas will be greatly appreciated.
You can download the gems instructions on MPI s site
If i put the mode #5 at 2.5 like they recomand and i am cruising at 7000rpm ,afr are in the low 10 even in the 9!
Lets be honnest the defaul setting is totally wrong for sea level!
I am not gona recomand anything to nobody for the gems.......
I can t make it work good enough!
I had 9000km on the sled and it never work how its supposed to... Always a lot of backfire headers is good ,red permatex everywhere to prevent any air leak..... To lean ,to rich....:mad::mad::mad::o|:o|
Guys who ride at sea level whit mpi trail kit. Can you post your gems setup the 5 mode please???
Ok. I'm at sea level. I used the exact same setup as the mpi websit recommends other then 2 settings.
First the green setting idle- I leaned that out so the green light was on 1. Not blinking, solid.
Second the cruise setting. I leaned it out also. The red/blue setting. Went from 3.5 to 5Remember the cruise setting is backward from the other 4 settings. Higher the number the leaner it is.
So your mode #5 is still at 2.5???? If i ride it a this number the sled make "" fireworks"
mode 1-1
2-3
3-3,5
4-5
5-6
I already bust 2 exhaust the third one is on its way to break soon.......
MPI said its too lean and i overheat the exhaust......!!!!!!!!
mode 1-1
2-3
3-3,5
4-5
5-6
My 5 mode is at 5 setting. But if your looking for richer you need to be at below 5. 1 is rich 10 is lean only with mode 5 the cruise mode. . What is your cruising afr numbers? I'm running around 11 afr cruising with the number 5 mode being set to 5.
Wow confusing on a message.
We are below 3000 feet. If I was you I would set yours up exactly like they say to. Other then the idle maybe. And then go from there
I'm at about 1000 ft and I run their recommended setting except I leaned the idle setting some
I'm generally around 800 ft above sea level. Settings I currently run after breaking in, getting some miles on the sled;
Green - 3
Yellow - 4
Green/Blue - 4
Red - 3
Red/Blue I don't remember.
Green - 4
Yellow - 4
Red - 3
Blue/Green - 5
Blue/Red - 3.5
Running at sea level. 9's and 10's at 7000 RPM cruise, Same for WOT. Backfires sometimes when I get hard on the Throttle from stop like in a Drag race.
Green - 4
Yellow - 4
Red - 3
Blue/Green - 5
Blue/Red - 3.5
Rich for surr
I leaned out the cruise setting and it made a big difference in both fuel mileage and afr numbers
Hey Joe, What is all 5 of your numbers?
Mine was crazy rich all the time till I made similar changes to what is mentioned above. I'm still having issues pulling proper rpm. I'm thinking the quiet muffler is causing a restriction on the system, making the thing run rich and robbing me of HP. It's a good bit faster than my friends stock xtx but doesn't seem anywhere near 170+ HP. I'm guessing around 155ish.
