wolfe9904
- Dec 29, 2013
Hay guys, just wondering if the Gen III tuner will fit the 09 nytro or do I need to get a different mount? My current tuner skis have a crack on the edge so I was looking for new skis with out spending big money
Hooray!
- Aug 12, 2017
- Maine USA
- 2009 Yamaha FX Nytro XTX
1998 Yamaha VMAX 700 XTC
Just bought Tuner IIs as heard the spindle is different for IIIs. Get similar keel depth with Bergstrom ski savers as they add 3/8" to depth.
wolfe9904
- Dec 29, 2013
yea , I was looking for II and came across the III. I dont want to spend alot on aftermarket skis
Hooray!
- Aug 12, 2017
- Maine USA
Went with IIs and Bergstrom triple points, wear bars, shims and ski savers. Nice setup, posted in my front end plus rebuild thread. Seemed like best bang for the buck. Snow will tell...
wolfe9904
- Dec 29, 2013
do you know if the pilot ski loops fit the tuner? I would like a white ski loop
Hooray!
- Aug 12, 2017
- Maine USA
budman 1000
- Jan 22, 2010
- Saskatchewan
- 2023 Yamaha LTX GT, 2017 Sidewinder XTX LE 137; 2015 Apex xtx, 2010 Nytro xtx turbo, 2008 Apex GT 40th, 2008 nytro rtx, 2005 RS Vector MTN turbo, 2001 VMAX 600
They will fit your Nytro, you just have to add 5/16” shim between rubber dampener and the skiyea , I was looking for II and came across the III. I dont want to spend alot on aftermarket skis
budman 1000
- Jan 22, 2010
- Saskatchewan
Also if you want to run tuners check out the 150mm tunerII ski, it’s 3/4” wider than the regular tuner ski and I run that wider tuner ski on my apex. One ski I’ve recommended to guys I ride with is the ski that the Yamaha Multi Purpose sled runs, it’s a wider ski with a shallower keel and actually works great on the Nytro
Hooray!
- Aug 12, 2017
- Maine USA
The 150mm Tuner II is what I just put on mine an heard similar good things about once you make a few corrections with the Bergstrom shims, reverse the rubber, ski savers, etc. Not sure how wide the Tuner III is but I have heard it has a 3/8" deeper keel than the Tuner II. The 3/8" ski savers duplicate this deeper keel and are still 150mm wide. Will report seat of the pants experiences this winter... SNOW!
