Problem seem to happen only when warm. Changed plugs. Seem to run OK when cold and seem to loose cylinders once a while when it gets warm. Ran the diag #32..Passed.
Anyone had similar problem. Can only be a bad coil?
The code 35 is not solid, only shown once today. I did checked all coils wires, also plugs were looking good.
By the way this is the first time my apex is having engine problem.
Thank you for your help.
anyone?
Code33 34 35 36 are related to ignition according to code list I got from someone on this board.
Yes I know, I got it from the service manual. The book suggest running diagnostic #32, which I did the coil test was succesful.
I'm affraid the problem occurs only when the engine is getting warm because everything runs OK the first 3-4 miles.
Not sure if a coil can go bad only when warm?
I guess I will get a new coil then I will be able to properly do the test.
Thank you
Thank you
Direct Attack
Check the inside of your spark plug cap. Had same problem on # 4 cylinder it was corroded. Do not now how or why it happened but dealer changed it out last week and sled is running good now. Something to look into. Just my two cents worth !
will check that, thank you.
