1slo_mm
I seem to have a similar problem (sorry for the hi jack from thread-Apex wont Start after short warm-up - Now Fixed author pro-trail). Last thursday I took mine out andit ran for a little bit then shut off on me. started it back up and i had a code 30 low oil. it ran for 30 seconds and shut off. i had to do this a couple times to get it back in the trailer. once i got home i tried it again and it just turned over. no pops, poor idling, or anything. sunday i changed the plugs (twice, both times with new plugs)and still nothing. i have good voltage, stong spark, and good fuel pressure. i cleared the code andthey havent come up again. it just turns over. ANY IDEAS?? thanks
Swiss Sledder
- Apr 18, 2003
- www.mi5.gov.uk
Split out your post so as not to hijack the other member's thread. I managed to lose SharkAttak's post in the process so it is below for reference.
SharkAttak said:stupid question, is it out of gas? check the fuel pump, when you first turn the key to on, do you hear the fuel pump? might be a fuse
jakeho
Just my 2 cents on SharkAttaks response. To us newbies that may not be a stupid question. We expect you so called experts to provide us with valid info and we truely appreciate your expertise. But, please do not be belittling us. I supervise students all the time in my profession and my belief is there are no "stupid" questions. Especially when you are learning something new. If you expect respect from us newbies then you need to respect the fact that we appreciate your expertise and experience enough to even ask you a "stupid" question.
- Jun 28, 2004
- Clinton, Wi.
I think you misinterpreted his response. He appears to me to be asking, in a conversational tone, if he is low on fuel. I try to look at post's as if I had written them and put a more positive spin on things. I agree that at times some response's seem harsh. Just try and weed that out when reading. Not everyone is patient with questions that they may have already responded to in the past. Not a bash of your post, just a little suggestion.
jakeho
Thanks for the advice Viper_Dave. Will try in the future.
1slo_mm
tank is full. fuel pump turns on. no blown fuses. checked cam timing, ok. tried new crank/cam sensor. tried new ecu. i have checked as much as i can think of and nothing worked, so im here looking for any other ideas. i talked to a few service guys and a mechicanic fimilar of turbo kits with no luck.. keep throwin ANY and ALL ideas out please!! thanks
