turkeystraw
- Nov 15, 2006
Stopped on the trail the other night and could see the inside of the muffler glowing red! Seems that there used to be a bit of carbon or soot on the muffler tip, but now she's real clean. Anyone notice this... was running 92-94 gas all weekend. Seems like it's running lean.
phaze5
nope i guess thats one thing i missed out on lol, but just before i finished her off i could hear it getting louder where my dealer put new gaskets on lol
buddhahead
- Mar 21, 2008
- Mid-Michigan
- www.shawwinkler.com
I havn't noticed it on mine. How many miles on it? I'm not an engine mechanic, but the phazer is fuel injected, so there may be a problem with the ecm...?
jet101ski
Its normal. Most all do it. Even other models do it.
Weapon X
jet101ski said:Its normal. Most all do it. Even other models do it.
Ah ha ha never you can touch my exhaust mid ride
SpeedRacer8888
buddhahead said:I havn't noticed it on mine. How many miles on it? I'm not an engine mechanic, but the phazer is fuel injected, so there may be a problem with the ecm...?
Definitley agree. Sounds like an really lean condition. Easy way to tell is to check the plugs and see how they look. I would get it checked out with the dealer.
YamaMamma
- Feb 5, 2009
- Alberta, Canada
- www.presentationsphoto.com
Mine glows red-hot too. We asked the 'experts' at a local Sled-Mod shop and he said it is normal. I am having other heat issues, so he did say it might be running a little lean, but in general, it would still glow red... I run Premium Gas (92 Octane).
Weapon X
Maybe cause my front hole is still open but my FMF never gets too warm.
turkeystraw
- Nov 15, 2006
2200 miles on sled, checked the air box...ok, maybe I will pull the plugs and see how they look. Front hole is also open.
Thanks for the response guys! Hope we don't have another Phazer meltdown.
jet101ski
If you are running the stock muffler, it will glow red a little bit at night, mine did it too! There is alot of back preasure in the stock pipe! When i changed to my procircuit pipe it runs alot cooler now. Less back preasure!
rhino_live
jet101ski said:If you are running the stock muffler, it will glow red a little bit at night, mine did it too! There is alot of back preasure in the stock pipe! When i changed to my procircuit pipe it runs alot cooler now. Less back preasure!
back preassure isn't an issue with the engine i'm assuming? like it doesn't back fire on you or sputter out?
Weapon X
No probs at all
