whitedust1
- Jan 10, 2008
- Waterford ,WI
- 2012 Apex XTX
I have a side panel sticker coming off around edges on my Attak. What glue do you recommend to to paste down the edges of the sticker?
smalltownpower
had the same problem on the vectors, 3M super77 spray adhesive. just be careful with it. i'm sure theres somthing other then spray adhesive, but thats what i've used and hasnt fallen off yet. warm the plastic with a hair dryer or heat gun first, dont heat the sticker cuz it'll shrink and disapear.
You can use clear nail polish if just the edge is starting to curl back.
whitedust1
- Jan 10, 2008
- Waterford ,WI
- 2012 Apex XTX
I put this sticker on myself after I power washed the old 1 off. Seemd ok then started to peel at all edges & I don't want it to get worse & come off. Nail polish may be the answer or an ahesive that applies with an artist brush. I just don't want to use an ahesive I can't get off later if peeling continues.
smalltownpower
spray adhesive from 3m will come off with "sticker off" or goo-gone, or wd-40
nate007
- Dec 25, 2006
- Iowa City, Iowa
- 1. '06 Apex -twin screw
2. '04 Redline Revolt 800
3. '09 Nytro XTX - twin screw
I found an actual sticker adhesive once after my trucks registration sticker wouldn't stay on, and I believe I bought it at O'reilly auto parts. its a very small spray bottle, probably only 2oz or so. If I can find it in the shop I'll post back what it was, but it worked really well, and car washes didn't hurt it after using it.
