You have to make sure the panel is very clean, I used a little heat from a heat gun or hair drier to heat up the area 1st, this helps alot. Used this method with reg. stickers. I always use stuff to shine up the body panels and this stuff can be hard to completely remove, but if you don't get it off the stickers won't stick well.
