Going in for service - Typical issues to check
Zrxpilot
Lindstrom Mn
Im bringing my sled in for service and come up with a short list of typical issues that have been discussed over the season. Not looking for advice regarding mods. Just want to come up with a list to have the dealer check that would leave you on the trail. Please add to the list
Warm start issue - Service bulletin
Loose chain tension
Loose coolant hose clamps
Muffler cracking
Fuel pump ground wire breaking
Reverse issue - Recall
Fuel line issue - Recall
Check to see if your sled is affected by the brake lever/master cyl issue ..
Check chain case cover for broken tabs, loose steering post bushings
  • Like
Reactions: RTX
I keep hearing this mentioned but no one ever elaborates on what this issue actually is.
Any chance you have more info on this?
The only sleds that this pertains to are the LTX LE (1.25" track) models that were shipped to dealers in the SPRING.
I was at the dealer yesterday getting oil and filter, was told next week 2 more recalls would be out from yamaha for the 14' viper
