canuck1000
- Apr 14, 2007
I recently cut my track down to 1" also went with smaller studs and went from 162 studs down to 108 studs also added 8" wheels with the offset axle.changed out all stock wheels to the 5.35" wheels. before this I could easily get in the 120's at 10,500rpm and with only 200 miles on sled now i'm having hard time getting 113 on speedo. since then i've added the cr10 plugs and ram air and still no top end. and now I have about 700 miles on it,sled is a 08 apex ltx gt. and i'm still reving 10,500rpm. and also it seems really strong on the bottom and mid range it just feels like something is holding it back on hte top.
SharkAttak
doesn't make sense, are your hyfax binding up?
LazyBastard
Put back ALL the original wheels.
SharkAttak
LazyBastard said:Put back ALL the original wheels.
how would the larger wheels slow it down?
LazyBastard
By sticking out.
canuck1000
- Apr 14, 2007
so you think the wheels would make that much of a difference. what about track tension, i don't have a scale but where the track hangs down the most its about 1 1-4". could that be to tight, or to loose, could it be balooning
SharkAttak
with my 135mm wheels, my track glides, i got alot more top end, when you put the 135mm wheels on did you get your holder's saved down so they didn't rub
canuck1000
- Apr 14, 2007
i'm using the 6205 bearings got the outsides ones machined flush, and the insides 0.060"
SharkAttak
canuck1000 said:i'm using the 6205 bearings got the outsides ones machined flush, and the insides 0.060"
i don't think it your wheels, i set mine with the doo wheels 135mm all 6 wheel, the narrower hyfax (old style yamaha ones), the slp anti-wear pads, in the closed holes, pulled up one on the limiter and run my track as loose as possible so it doesn't rachet, never had a problem on my attak, done 117 on radar, my track glides
ecopter
Goes to show everyone how good these sleds run stock.
jf
jf
SledFreak
- Feb 7, 2005
- Ontario. Canada
Your spinning? How far of a distance are you running?
canuck1000
- Apr 14, 2007
sledfreak i think you maybe right it feels like the powers there but just not going anywhere, i'll try adding more studs and see how that works.
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
If you were spinning I think your speedo would be reading higher?????
SharkAttak
SledFreak said:Your spinning? How farof a distance are you running?
sledfreak, i see your running 1.450, do they bite good, also, how close to the exchanger are they
canuck1000
- Apr 14, 2007
Well i addedd more studs, brought my co up from 7 to 10 loosened my track 2 full turns and the most likely thing i think ,was i forgot that when i had my suspension out i adjusted my control rod to min transfer put it back to almost max. i'm back in front of my buddies F-1000 with Y-pipe mod, and top end kit.
- 7K
