gorilla axles????
i have gorilla axles in my quad and im starting to wonder about em i have a 2in lift and 27in swamp fox's.. yesterday my front brakes got soft unless i pumped them. so i pulled the front tires off and found the front right axle nut sheared off right at the hub... would 2in wheel spacers do this or a failed wheel bearing.?.?.? i did ride it about 25-30 miles with the "brakes feeling soft" and i also found the bearing has a little play in it .. (way to much) what would cause this faulty axle, wheel bearing, spacers, or just tough riding???
