dylanjen9
When I put apex in reverse it just makes a grinding noise. Guessing linkage needs to be ajusted. Which way do I move the linkage?Do I make linkage longer or shorter?
Jona$
Master
- Sep 27, 2010
- Northern
- Sweden
- Tapex/sks 800 -16
The upper link should measure 27mm from the inside of one jam nut to the inside of the other, the lower rod should be adjusted so that there is zero free play when in the forward position.
dylanjen9
Adjusted linkage but it still wont engage in reverse. When on a stand the track will spin but on the ground I can hear it grinding. Just had the chaincase apart Did I forget something or should I adjust the linlage more?
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Make sure your chain is adjusted properly...finger tight, then back off 1/4 to 1/2 turn.
Handy
- May 12, 2005
- Anola Manitoba
- 1983 Bravo, 1988 XLV, 1991 Pazer II, 2005 Vector, 2006 Apex Super Charged, 2017 Viper STX DX 137, 2018 SR Venture DX
It almost sounds to me that you didn't get the shifter fork into the slot on the sliding gear.
dylanjen9
Pretty sure I put shifting fork in but does it go on from the top or bottom?
thrasher
- Nov 22, 2006
- Ottawa Valley, Ontario
- 06 Vector RS ER
Had the same issue when put my chaincase back together. Didn't have the fork in the sliding gear properly. Pretty sure the shift fork needs to be on the top.
Handy
- May 12, 2005
- Anola Manitoba
If I remember correctly the fork goes in from the top. It's kind of a pain to get it in, just take your time.
Vectornut
- Nov 18, 2007
- Eden, Vermont
- RS Vector
I didn't think the chain case cover would go on unless the fork was inserted correctly. Thats how I remember it.
Handy
- May 12, 2005
- Anola Manitoba
Yes it will go on but reverse will not work.
