just went threw whole wiring harness an cleaned every possible ground on sled just hate to start throwing parts at it because any other sled iv owned that had stator problem it just was running or dead that's why leaning towards grounds because just got back from a 500 mile trip an it still runs just was showing 46 code once maybe twice a day for about a minute or so would run like crap when code was up then clear itself an run fine the rest of the day just frustatingCheck nd blocks if you have not done so as of yet. They have been known to cause erratic electrical issues. Also check the white plug that is beside the battery and between two fuses. This plug does corrode and will also cause issues.
