I'm a "newbie".....I have a 07 apex GT and somewhere around 3800 miles I had a rear center guide wheel failure. ( Didn't see the damage till I returned home from trip). Is this a frequent problem with Apex's? ...snomo53[/b]
If you are talking about the center of the large rear suspension wheels it's probably a bearing failure. Check all the wheels and see if they turn freely, it not replace. I replaced almost all my wheels at 3,800 miles, a couple were so bad they would not even turn. Be sure to add the 4th wheel in the rear, it will save you and get you home someday when you lose an outside wheel (speaking from experience).
