mtotguy
- Jan 20, 2011
- Montague, Michigan
- 2016 Rush 800, 2014 Viper RTX, 1983 Excel 3
From the first time I rode my sled I didn't like the brake. I mentioned it in a couple posts here. I had the sled at my dealer for the no-start issue and mentioned the lousy brake to him. They found that the brake disk was siezed to the drive shaft. It appears to have been forced onto the shaft at the factory. (It's a splined shaft. I'm not sure how they could screw this up) The dealer couldn't get the disk off the shaft. They had to replace the shaft, disk, caliper and pads.
TestMaster
- Sep 28, 2013
- Alba, Michigan
- www.gdls.com
- 2014 SR Viper LTX SE
2014 SR Viper LTX DX
2001 Venture 600
Given to a friend - 1998 SRX 700s
Good to see that the dealer tore into the issue well enough to find the problem and didn't just look at the symptom, replace brake shoes, and sweep you out the door!
mtotguy
- Jan 20, 2011
TestMaster said:Good to see that the dealer tore into the issue well enough to find the problem and didn't just look at the symptom, replace brake shoes, and sweep you out the door!
The only problem is that he forgot to put any oil in the chain case. Fortunately I looked everything over prior to riding it.
yam177
- Aug 14, 2008
- Shoreview MN
- www.jbeurotech.com
The discs just sieze, they are a pain to remove your dealer was just kinda clueless. We have to swap them from Ice racing as they warp. They suck to get off the first time.
yam177
- Aug 14, 2008
- Shoreview MN
Don't forget teh drive shaft brake responds wait different than the jackshaft one. Way more pull involved, not to mention not a fan of the Hayes system. Took me a while to get used to the lack of braking power
mtotguy
- Jan 20, 2011
This sled only has 1100 miles on it. Are you saying I'm going to need to replace the disk several times a year? My Nytro has 8000 miles on it. I've had the nytro brake so hot it fractured the brake pads. I've never replaced the disk and it has never seized to the shaft.yam177 said:The discs just sieze, they are a pain to remove your dealer was just kinda clueless. We have to swap them from Ice racing as they warp. They suck to get off the first time.
yam177
- Aug 14, 2008
- Shoreview MN
No we only warp them running hard on the ice races. We warped just as many Nytro Discs. Drill an extra hole or reverse the Brake disc guard to get extra cooling in it
